Announcements
FEA simulations error - mesh to coarse
robinMGH52
robinMGH52
I am student mechanical engineering and at the moment I am working on several FEA simulations for a project. I do static event simulations and in the scenario, I simulate, the forces are in equilibrium. The function "remove rigid body" is activated during the simulation. Unfortunately, the simulations fail. You can find the warnings in the attachment. I think that the mesh is too coarse. The model has walls with a minimum thickness of 0.6 mm and the smallest "local mesh" mesh that is possible for this model is 2.5mm. If I activate the absolute size for the general mesh and set this to something smaller than 0.5mm crash my computer. So, does anybody know how I can solve this problem?
Replies (8)
dsouzasujay
Hi @robinMGH52
Could you please attach the dataset, I see errors while generating contact.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
robinMGH52
Thanks for your reply. What do you mean with "the datasheet"? In the attachment you can find pictures of the report. I can not upload the report, because of his format and unfortunately, I can not change the format.
robinMGH52
Datasheet = dataset
dsouzasujay
Hi @robinMGH52 ,
Sorry for using technical term.
I mean your file.
File>Export your *.f3d/*.f3z file to your local drive and then attach it here to a reply.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
robinMGH52
Hi @dsouzasujay
Thanks for the help. However, I already managed to solve the problem.
Kind regards,
Robin
sutherland-
Hi @robinMGH52
Could you please share how you managed to fix it in the comments and press "Accept Solution" on your own post, so that other members can see how to fix the issue that you were facing.
Thanks in advance.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
dsouzasujay
Agree with @sutherland-
Please share how you were able to fix the error, other users will get help when they get struck with same error.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
robinMGH52
The model was solved after I changed some mesh settings. The main change was the element order from parabolic to linear
