Announcements
FEA FAILING, ASSEMBLY CONSTRAINTS FAILING
ReachShaun
ReachShaun
Hello all,
I have an assembly, nearly fully constrained. However, the last constraint will not take hold without causing errors with other constraints. I desperately need prompt help. I believe that due to this reason, my FEA stress tests are also failing. There is a meshing issue. However, I have solved the issue and completed the mesh only to attempt running FEA and have it failed, repeatedly. All parts are ABS. I have attached the assembly file. We can start here and progress once someone is providing assistance. I look forward to your guidance.
TheCADWhisperer
Where did your Timeline go?
ReachShaun
The design didn't originate from this file. It was a STP file, modified by
me.
