Announcements
fbx export: path to body different than in fusion
watts.kym
watts.kym
This is one for the devs maybe.
Id like to map some data in fusion to an fbx export from the file.
But there is a mismatch in the naming of how the fbx stores the body vs what it looks like in fusion.
i wrote a bit of python to give me the hierarchy/namespace that is similar to that of the fbx.
fusion path to body:
LEG v1/KNEE v1:1/Big Drum Assembly:1/Crank:1/Body4
fbx path to body:
LEG v1/KNEE v1:1/KNEE v1/Big Drum Assembly:1/Big Drum Assembly/Crank:1/Crank/Body4
Can someone confirm what the rule is for these fbx paths?
Am i safe to assume that the root & body names are the only parts of the fbx path that do not get name.split(':') extra item in the path?
Cheers
Kym
Replies (0)
