Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Support
Report issues, bugs, and or unexpected behaviors youā€™re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Fasteners - joints into a subfolder
5 REPLIES 5
chris.frakes
262 Views, 5 Replies
Hi, would it be possible for the joints created by adding fasteners to be automatically put into a subfolder of the main joints folder to avoid clutter? Thanks
5 REPLIES 5
Roman_Vesely
in reply to: chris.frakes
Hi chris.frakes,
 joints of inserted fasteners are autimacially in subfolder of the Joints folder of  the ACTIVE Component. The same behavior as you can see when you insert Xref document and use manual joints.
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
@Roman_Vesely I think what @chris.frakes is asking for is a folder in that subfolder specific to that group of fasteners.
chris.frakes
Hi, thanks for the replies and my apologies for not explaining more clearly.
When adding say a bolt, nut and washer there are 3 joints automatically created. So adding say a dozen such fasteners and the number of joints in the active component grows by 36. If these joints were in a "Fasteners" subfolder of the respective Joints folder, navigation would be easier and it would be faster to find user created joints vs. ones created by the addition of fasteners.
Roman_Vesely
Hi chris.frakes,
I see your point. It's interesting and it will be forwarded to our Designers for future investigation.
As "workaround" right now you can see in the TimeLine that each Fastener (if  has a joint - so joinded with some geometry) has his joint(s) directly on the right side of it's icon. Hope that could help with identification of joints related to fasteners.
 Best regards
 Roman
Roman Vesely
chris.frakes
in reply to: Roman_Vesely
Hi, thanks for your time and consideration.
My goal was really to separate auto-created Fastener joints from user created manual joints to make the latter easier to find for further actions (e.g. editing) If Fastener joints are grouped and collapsed into a subfolder of Joints, they're easy to find if needed but more importantly, user created joints are still presented as they were before the Fasteners functionality was added.
