FANUC Milling Post
cncohio
FANUC Milling Post
cncohio
After the last update the FANUC milling post is spiting out a ton of S codes through out the post. Even if I delete them the path is still wonky. I saved an older post I was able to load and use that  one. I didn't go through them to compare what was changed just letting you know something is not right in the updated post.
cncohio
I went into the tool page and changed the spindle speed default values, it dropped all the extra spindle codes. Sorry about that I was just used to changing them in the editor I never had that happen YET I should say. Didn't mean to waste anyone's time.
