Fusion Support
Failing to update
7 REPLIES 7
Message 1 of 8
guselfvpa
265 Views, 7 Replies
Failing to update
Fusion is failing to update for me, I am on a Microsoft Surface pro 3 Win10
Attached log file as suggested.
Kind regards
Patrik
7 REPLIES 7
Message 2 of 8
@guselfvpa Thanks for the logs. It shows the below error
OSError: [WinError 1392] The file or directory is corrupted and unreadable
Here is my recommendation:
1. Close Fusion
2. Delete the shortcut you use to launch
2a. Restart machine
3. Go to add/remove programs
4. Select Autodesk Fusion - Modify
5. Select repair Fusion
This should help.
This will launch the
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 8
I have now tried this, with no success unfortenately.
Any other possible remedies?  would uninstall and install remedy?
Kind regards
Patrik
Message 4 of 8
@guselfvpa I am a bit surprised that this did not work. Essentially that is an uninstall/reinstall. To confirm that you are now able to use Fusion just that you cannot update it? Can you tell me what is the version of Fusion you are currently on? Also, certainly do the uninstall and a reinstall will install the latest build.
Autodesk Fusion
Join Fusion Insider
Message 5 of 8
guselfvpa
in reply to: guselfvpa
Yes it works fine but is not updating.
If I try to uninstall via the dashboar thing or via apps and programs I am met with the below error message. Does this mean I need to resort to other ways of uninstalling?
I am on
Fusion 360 2.0.17721 x86_64
Active Plan: Student
Windows 10 Pro 22H2 (19045.3803)
Kind regards
Patrik
Message 6 of 8
@guselfvpa Ok, looks like you want to do this then:
1. Again close Fusion and restart machine (Just to be sure)
2. Goto C:\Users\(username)\Appdata\Local - Delete the Autodesk Folder
3. Now install Fusion again
Does that help?
Autodesk Fusion
Join Fusion Insider
Message 7 of 8
guselfvpa
Thanks Rajkumar,
That worked like a charm.
Best wishes for 2024
Patrik
Message 8 of 8
@guselfvpa @Glad to know this worked.
Autodesk Fusion
Join Fusion Insider
