first of all – sorry if this is a trivial issue, this is my first modelling project.
I was trying to create a cylinder that can be screwed into a camera lens filter thread.
To make my cylinder fit, I need a 67mm diameter (lens thread size) and a 0.75mm pitch, according to this thread: https://photo.stackexchange.com/a/90955/94933
Because there was no preset for my needs, I created a custom thread profile with the correct pitch size and diameter.
Unfortunately, Fusion 360 will fail with the message "Error: Failed to build thread tool body." when trying to enable the "Modeled" property on the threading tool.
Prior to this approach, I tried to create a coil with the same measurements, but Fusion 360 throws the same error for all pitch sizes under 10mm.
What am I doing wrong here?
Thank you so much.
