I have a big problem with this assembly file. I am not able to open it anymore. Not even an older version it. They all failed to dowload. I can see the desing in the Fusion online hub, but can not dowload it as fusion3d extension. I could dowloaded as step file, but neverthless when I open it in Fusion it still throws the same error "failed to dowload problem".
Since i had a files stucked in upload I cleared the Q folder and UploadQueuedFileList as mentioned at this link https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fil....
This is an import file for me. I do not understand why all of the sudden I can not open it anymore. Plus if it is in the online server why I can not simple download it again?
Thank you.
Best,
Alessio
