I created a simple rectangle and extruded it...made a center plane on xy axis symetric. Constructed circle on center plane. Can not extrude the circle two ways for embedded magnet. Constructed vertical center plane and did a section view. then selected the circle, now it can be extruded...what gives? I can do this two way extrude in Onshape, no problem.
I am adding to this post. After extruding the circle in the setion view analysis, the magnet hole appears. If I turn off the section view in the browser, you can not see the extruded hole any longer...you can see the magnet hole in Onshape in section view as well as the normal view.
