Announcements
F360 online - Save as DXF
pajasry
pajasry
Hi there,
at school we are using Fusion360 online. Everything works fine. but when i tried save sketch as dxf, it was saved to virtual machine. Not mine(host machine). Is there some kind of workaround? Can i somwhere submit/request bug report? Will it be fixed?
jodom4
@gmelantoni , can you offer some advice for this issue?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
MichaelCottrell
Observer
Observer
I am also having this issue. has anyone discovered a solution/workaround?
HughesTooling
I replied in another thread with this,
I think the only option would be to have the sketch in a component, then use Save Copy As or maybe Derive to push the component out to a project in your hub then using the web hub interface download the "Pushed" design as a DXF.
Edit. Note exports from your hub will be in CM so you might need to scale in the software you're exporting to.
Mark
Mark Hughes
Owner, Hughes Tooling
Facing the same issue.
It would be great if we can download the exported dxf file from the virtual machine, or the exported file exists on the Fusion Team project page.
