Hi Jeff,
Making a planetary gear using the FM gear addon. It creates perfect gears but they can't be 3D printed because there's no provision for tolerances.
The number of curves and lines it creates is in the 500 range not thousands. I don't remember the exact number.
by offsetting the tooth profile 0.2mm, I can make the internal ring gear wider and get the tolerance I need.
After messing around for hours, I gave up and did it in SolidWorks in 2 minutes!
Fusion360 needs a lot of work judging from how many times it crashes and sends in crash reports, which I never hear from again.
I used to teach AutoCAD to draftsmen at Boeing in 1985. I was expecting a lot more powerful software after all these years of evolution. Instead, I find an extremely slow software with a finicky UI that doesn't register many inputs, crashes often and goes for breaks once in a while with no apparent cause.
Sometimes double clicking a operation on the history line works, sometimes it doesn't. Game of dice!
The only thing that sets this software apart from SolidWorks, is its top-down assembly and file creation.
I am a power user and often find bugs in all software, but F360 has its share.
Thank you.
