Hi all,
I'm having some trouble getting Fusion to export a flat pattern correctly.
The sheet metal part I am working on has a text cutout which, when our laser cutter is loading in to their nesting software is producing some strange geometry issues.
Workflow to export DXF for laser cutting has been:
Create flat pattern > Create sketch on surface > save sketch as .DXF
Images of what is appearing at the cutters end attached alongside the .F3z part file.
EDIT: I should add, I have tried exporting the DXF and opening back up in Fusion & another software and it opens and appears correct.
