Announcements
F360 Crashes on Startup
williams.devauden
williams.devauden
Hi, I'm using F360 on a 2017 3.4Ghz Quadcore iMac running MacOS 12.6.9.
I experienced some significant instability and frequent hanging this week prior to the latest update and since the update, F360 and the Service Utility just crash on startup. I don't get a F360 crash report, just Apple.
Please advise.
Regards, David Williams
RajkumarIlanchelian
@williams.devauden To start with is it possible to do a repair of Fusion 360 and see if that helps?
1. Close Fusion
2. restart Mac
3. Go to Launch pad - Fusion service utility
4. Run the Repair Fusion
Does this help?
Also if there are any pending macOS updates, please update them as well.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
williams.devauden
Hi, thanks for your response. I have tried all of the above several times. The big problem is that the Fusion Service Utility also crashes with the same Apple errors as F360 when I try and launch it from Launchpad, so I can't repair the F360 installation. Regards David
RajkumarIlanchelian
@williams.devauden
1. Are there pending macOS updates?
2. If you Go into launch Pad and select Uninstall Fusion/ reinstall Fusion does that help?
Autodesk Fusion
Join Fusion Insider
williams.devauden
Hi, thanks again for your response. All Mac OS upgrades have been applied. I think that the last F360 update didn't properly complete and has somehow corrupted the installation.
I'll try uninstall / reinstall.
williams.devauden
All good now, thanks
