Extruding Projected geometry is creating random faces/planes that aren't quite perpendicular and become impossible to fix
pmally
pmally
I've been having an issue that has become a major problem in the past week. Projected geometry from perpendicular planes creates non perpendicular faces. If I zoom in all the way I can see the faces and try to fix them, but this often breaks the model and I can spend hours trying to fix these faces so I can continue on with the design.
A single face seems to get divided up into several pieces all with slightly different heights or angles.
Zoomed out viewZoomed out viewclose up showing uneven facesclose up showing uneven facesanother exampleanother example
jhackney1972
Please attach your model to your forum question so the forum users can better help answer your issue.   To do this, open your model, click on File -> Export to your hard drive and then use the Attachment section of the forum to attach your model.
John Hackney, Retired
