Message 1 of 12
08:42 AM
Hi everybody,
I came across an error that I haven't seen before but experienced with more than one project.
When I try to extrude a sketch starting from an object and to another object that's between the plane of first object and the sketch I get a zero distance error even though the distance is not zero and it's correctly show in preview. This error only happens when I select from an object to an object. If I select distance then it works correctly. Before someone tries to tell me not to extrude backwards I need to do this to create tapered stand-offs where the top of the stand-off is a known size.
Attached picture might help.
Thanks!
