Extrude works on Thin not Solid.
Dykstramd77
Dykstramd77
I have been redesigning my part and I cannot Extrude a solid the thin extrude works fine? I did notice that one sketch that works, and it has a light blue background color but the sketch that does not work has no background color. I have tried to redefine the sketch plane with no change I would prefer to have the sketch on the main origin axis but that did not work either??
HughesTooling
I f you edit the sketch is Show Profile checked? Please don't attache pictures, just paste them into your message.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Something else to look for, if you window select all elements in the sketch is there an option to move to sketch plane? You need to be editing the sketch.
Mark Hughes
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Dykstramd77
Thank you for your help with my sketch and forum skills.
