Announcements
Extrude two separate sketches on same plane
vbarrera86
vbarrera86
Hi there. I am new to Fusion 360 and I'm trying to extrude a two separate sketches (see image below). I'm trying to have one giant square and then another square that is extruded from the larger solid. I am created a simple basic camera idea from the tutorials I'm following. Thanks so much!
jhackney1972
It is really hard to answer your question correctly without your model and a better explanation of what type of Extrusion you desire.  Two Extrudes Join, Cut, Intersect...  please define you needs.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
vbarrera86
I am trying to do exactly what you are showing in the video. I seem to have drawing both sketches on the same plane, but they are not on separate files - not sure if that's the problem. I attached the file I'm working on.
jhackney1972
You have created a Component in your model and placed the sketch under it.  All you do is Activate the component, before you extrude, so all you bodies go under the component.  Screencast will show.  I added my the model, yours, in used in the Screencast if you need it.  If this answers your question, please Accept Solution to close out your Forum question, if not, post any other questions.
