Extrude tool bug
I've got a component that I want to add a rebate to:
I've created a sketch on the face and added the line with dimensions.
I then close the sketch and try to use the extrude tool with cut and minus dept to remove the section.
The preview shows exactly what I want but when I click ok, the component cut disappears.
After a bit of experimenting, I've found that the extrude changes direction after I click ok, so if I extrude with the join option longer than the component, it sticks out from the correct face but through the component.
I've even tried entering a cut with a positive distance but it won't let me, so I'm stuck.
