Fusion Support
Extrude only working in the negative direction
6 REPLIES 6
k.c.clark
224 Views, 6 Replies
I'm trying to do a simple extrude I've done hundreds of times.  All the sudden it only works in the negative direction. I've attached two screen snaps.  One that works in the negative direction and another in the positive direction.
Tags (1)
6 REPLIES 6
asiudaisd
in reply to: k.c.clark
Maybe the wrong component is selected
HughesTooling
Any chance you have a section analysis enabled?
Also please don't attach pictures, just paste them into you message.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Marco.Takx
Hi @k.c.clark,
Can you please share your file?
Without seeing it, it is hard to help you with your problem.
Within Fusion 360, choose File > Export and save it on your desktop.
After that upload it to this topic so that one of us can take a look at it.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Consultant
HughesTooling
Just adding a picture to show same behaviour with a section enabled.
Mark Hughes
k.c.clark
in reply to: Marco.Takx
Here is the file.   I will look into component selection and enable selection analysis.
TheCADWhisperer
You did not post screenshot of error.
Your file works fine on my machine.
Did you reboot your computer and the problem persists?
I did notice that you have an unconstrained line in this corner (I dragged it out), but this should not cause the behavior you observe.
