EXTRUDE default distance changed with patch? Troublesome!
r.augusiewicz
r.augusiewicz
Hello!
Have anything changed with the extrude default value with the latest patch? I have always started with 0 and since I extrude many different distances I was perfectly ok with that, for one - it let me decide by myself and for two - I can click all surfaces and only then put down the number of distance for extrusion.
Current state is that default distance value is stored from the last extrude option and I:
- never use the same number so I have to delete the number each time which is time consuming and can bring errors (already did)
- the already extruded body is taking more memory and is lagging my Fusion while I want to click like 10 faces and only then write the distance number.
Please help me I am getting crazy here working this out....
Rafał
jhackney1972
A Fusion 360 patch was released today for this issue.  Please update your Fusion 360 to version 2.0.10446
John Hackney, Retired
jeff_strater
this has been corrected in today's update, I believe.
Jeff Strater
Engineering Director
