Announcements
Extrude/Cut direction is reversed on mirrored part
Message 1 of 8
I have a very simple part which is the mirror of another part. For some reason, when I sketch something on planes parallel to the mirror plane and try to extrude or cut the body it appears to fail. What's actually happening is the preview shows the extrude/cut happening in the correct direction, but the applied extrude/cut is happening in the opposite direction meaning it either extrudes into the body or cut nothing.
I saved the part into an external file and it works fine.
I deleted the mirror and made the part again from a mirror but it's giving me the same issue.
Extruding/cutting on planes perpendicular to the mirrored plane work fine.
I started a brand new design to test the issue and was able to confirm it happening there as well.
Replies (7)
Message 2 of 8
jhackney1972
I cannot replicate your failure when I create a model using your description.  Please attach one of yours that exhibits this problem.
John Hackney, Retired
Message 3 of 8
Component B(mirrored), features Extrude 1 and Extrude 2 both have the issue for me.
Message 4 of 8
g-andresen
I was able to recreate this in a new construction.
@dsouzasujay  can you take care of this?
günther
Message 5 of 8
dsouzasujay
Hi @g-andresen @Anonymous @g-andresen
Thanks for reporting this issue! I agree this is a bug and also annoying, reported asFUS-81578 in internal issue tracking system. Hope we get it resolve sooner.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 6 of 8
This looks like this thread as well. Only punching in the opposite direction does not work either.
Can not punch holes in mirrored componenets
Message 7 of 8
aurimas_karosas
rotating the component by 90degrees cuts the object.
might be a solution for some until the bug is fixed
Message 8 of 8
Does anybody know when the bug will be fixed?
