Fusion Support
Extrude changes with constrained sketch
2 REPLIES 2
benQNT9Q
134 Views, 2 Replies
Hi All,
I'm having an issue where an extrusion doesn't update correctly and can't figure out why.
The sketch is constrained and when I extrude it is correct, but when I click okay, the extrusion changes.
What am I doing wrong here.
Video link - https://watch.screencastify.com/v/5G2McMWXtcAqQtDntm20
Model - https://a360.co/47de9AR
2 REPLIES 2
jhackney1972
in reply to: benQNT9Q
Does this explain it?  I am showing the shelf, in question, and the Rear Panel in a Sectional Analysis.  You have a Joint holding the shelf in position, when you edit it the sketch moves to the original created position and then jumps back when you finish.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
benQNT9Q
in reply to: jhackney1972
Hi @jhackney1972 ,
This is it, thank you.
