Extrude Along A Path
Ethan_WittZB3EZ
Observer Observer
Ethan_WittZB3EZ
Observer
Observer
Hello, I would like to extrude the "T" Sketch along the connecting line using the "Loft" command. I was using the "rail" constraint. The rail line is made of 3 lines so when I try to use it I get an error saying the rail does not intersect with all the plains. Can I please have some assistance on how to complete this extrusion?
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
jhackney1972
All your sketches are not defined so they can move at will.  You also have a duplicate path sketch.  In the video I create your model but as you can see the Sweep path is too short to give you a good results.
(view in My Videos)
jhackney1972
I have taken your model and recreated it to give you an example of a fully constrained sketch.  The dimensions of the path were slightly modified in order to the a radius to develop on the bottom leg of the tee.  I hope this gives you can idea how to create a stable and usable model.  Model is attached.
