Extract Render Settings from Previous Renders
I found that rendering is a lot of trial and error. I often try out different environments, light positions and so on. In doing so, I end up with at least three different render settings and it did not only happen ones that the first or second setting turned out to be the best. If the position of the model was perfect in that render, it is not a problem but often I want to turn it a bit more or get a second perspective and here my problem arises. I can not get easily the same settings again because Fusion only remembers the last setup.
Therefore, it would be great to just copy the settings from a previous render or at least see them somewhere.
