External CAM kernel error
I'm getting this error:
Enabled feature flags: setup-sheet-viewer tool-library-v4-release
Invalidated: Generation failed
Error: Internal CAM kernel error. Please report through your support channel.
Yesterday everything was fine, but when I cut out the part, I noticed extra wood around some window cutouts as well as the part itself. Then I remembered that the radial stock to leave value was .2 and should have been 0. I changed it to .2 and now I'm getting this error.
To troubleshoot the problem, I changed it back to .2 -- still getting the error but now the tabs I had set look way too wide, wider than the tool diameter. I removed them and put them back but they're still showing way too wide. The default value changed to .125 in so I changed it back to .063 in which is the equivalent of the tool width of 1.6 mm.
Now I'm stuck and can't seem to get the toolpath generated even back to what it was. I want the radial stock to leave set to 0. I kept fooling with it and now the tabs look right in size and radial stock to leave is 0 but I'm still getting the error.
