Extend display region of a construction plane
meatmyplaceautod
meatmyplaceautod
I am new to F360.  I'm on a private license and still learning.
I have searched and found the exact same question/problem as per the link below.
The question was solved but somehow I can not find a way to resize the plane block.
I did look at the solution given but it does not work for me.  I did look at other related questions and it suggest to ensure not to be in "sketch mode".  I've tried in and out of sketch mode.
I've seen suggestions of ensuring "selection filter/work geometry" to be visible.  Still does not work.
Please help.  I have a couple of objects that remain bigger than the plane block and it would be easier to enlarge the plane block than having to remove visibility of the objects every time I want to refer to the plane.
Ref to old solved related question.
https://forums.autodesk.com/t5/fusion-360-design-validate/extend-display-region-of-a-construction-pl...
jhackney1972
You had the answer in the Forum post your referenced.  Left click and drag on any corner or edge.  This method cannot be used on the Origin Planes.  I demonstrate in the Screencast.
John Hackney, Retired
meatmyplaceautod
