I have spent hours looking over everything and cannot seem to find the source of my errors, if anyone could help me I would be so thankful. Below are the errors as well as the shared file.. I am trying to mill out that pocket for a grease groove on a part that everything else machined fine..
Error: Direction is not supported for machine configuration.
Error at line: 2382 (haas next generation.cps)
Error in operation: '2D Pocket2'
Solved by a.laasW8M6T. Go to Solution.
Hi
You are using tool orientation to set the machining direction flipped from your setup orientation:
being that this is probably on a 3 axis machine this isn't the correct way to do it. you need to have the setup orientation correct and don't use tool orientation
Change the orientation to "select Z and X axis"
Ohh my gosh, you are a life saver. I don't know why I couldn't figure that out, too much going on at work I guess when I was trying to finish that.
Thank you so much for taking the time to help me out, I greatly appreciate it.
