Announcements
Exporting a part in Fusion format.
rbenward
rbenward
I have created a large telescope equatorial drive.  I wish to export the worm and bearing assembly.  This part is several solids under a folder.  How can I make this a separate Fusion part that I can bring into other designs?  I don't want to export to other formats, as I will lose properties that are embedded as part of Fusion.
Bob
g-andresen
 right click > "save copy as" should achieve what you need
günther
jhackney1972
I would like to add to @g-andresen answer, which is what you want, and that is the Save Copy As statement ONLY works on Components, not bodies.
John Hackney, Retired
rbenward
Yes, I realized that it only works on whole components.  The problem it is easy to start a sketch on the wrong level, and then you are way down the road.  Still a newbie here.  You can't move the sketches or bodies in the browser tree to fix mistakes.
Thanks for the responses.
Bob
