Fusion Support
Exported STL file location
4 REPLIES 4
alexjpage
152 Views, 4 Replies
Please can someone tell me where to find an exported .stl file? When I export, I only have the option to export to some 'project' locations like 'admin project' and not regular folders on my hard drive. I need to transfer the .stl file to a flash drive to take it to the printer, so a cloud location won't work.
4 REPLIES 4
HughesTooling
in reply to: alexjpage
Are you using the browser version of Fusion? The desktop version should have the option to save to a folder but the online browser version is running on a remote desktop that has no access to your local drives. If you save to the cloud you can download the STL file in Chrome from your hub.
If you're using the desktop version of Fusion it should have the option to save the your computer on the Save As dialog.
Mark Hughes
Owner, Hughes Tooling
alexjpage
in reply to: HughesTooling
Thank you very much, I'm using the browser version. How do I find my hub and download the .stl file from it?
HughesTooling
This link should take you to your hub, then just navigate to where you save the stl.
After navigating to the Project just hover over the file yo get the download option.
Mark Hughes
alexjpage
Thank you very much indeed, that worked!
