Fusion Support
Export to STL not possible
3 REPLIES 3
gillesbielmann
160 Views, 3 Replies
Fusion 360 can no longer export to STL.
The progress bar doesn't move at all, even after several hours.
I've tried with other drawings, cleared the cache, restarted the computer, reinstalled the program but it still doesn't work.
I don't know what else to do. Can you please help me?
3 REPLIES 3
You should use the Save as Mesh command instead of Export. It is much more efficient and offers some advantages. Select your Body in the Browser, right mouse click and select the command. Set you desired parameters in the dialog box (not shown) and save your file.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Phil.E
in reply to: gillesbielmann
There is a new build of Fusion that should have a fix for this. Can you please update Fusion to build 2.0.18220, which was released yesterday, and let us know if the issue is solved for you?
How to update Fusion
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Thank you really much, soir solution Works fine !
