Fusion Support
EXPORT to STL Issue, since most recent update
0 REPLIES 0
Message 1 of 1
maalamJGUHU
42 Views, 0 Replies
Ever since the most recent update that I got in the last day or two, the Export to Stl function does not work the first time. So, when I highlight a Body and export it to stl, it saves the design and then freezes with no progress to completion. If I cancel it and immediately repeat the process, it works correctly. And when I exit Fusion 360 it tells me that an unfinished process is running, and whether or not I should exit anyways.
I am aware of an alternative way of exporting to stl using Save As, but I wanna report that an existing function has broken in the most recent update.
0 REPLIES 0
