I have been trying for 2 days to export some of my original drawings to STL's and the process always comes back "failed" after taking forever to attempt the processing. I know its not a local computer issue because I have two systems running the same version of Fusion 360 having this exact same issue.
windows 10 system, I7 10th gen, Fully solid state storage, 64gb ddr4, Nvidia 3060
This process worked perfectly until yesterday morning. No updates had been done to my knowledge. Please let me know if there is anything I can do to fix this?
Don't use the export menu. Right click on the name of the body and choose "Save as Mesh". Or go to the UTILITIES tab and use 3D Print.
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
