Export not working ?
Message 1 of 8
When I click on export from the file menu , nothing happens. Is this bugged ?
Replies (7)
Message 2 of 8
wmhazzard
Export works fine for me. What are you trying to export? Personal license?
Message 3 of 8
I am on the educational license, the export feature has not given me any issues until today. When clicked it does not even trigger a prompt. I have closed the program and reopened and does not work , and tried different files , same thing.
Message 4 of 8
I have also noticed that when closing the program , it is asking me to generate an error report , but no apparent indications of a crash except that the export window will not prompt. I did notice something strange with the opacity settings of clear glass objects being set to 100% randomly. I don't know what's going on.. maybe I need to re-install ?
Message 5 of 8
HughesTooling
You might need to do a clean uninstall using the tool Here. I'd restart my PC after the uninstall then reinstall Fusion.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
Thank you , the un-install worked.
Message 7 of 8
lange_18
i have the same problem but mine will export but empty files
Message 8 of 8
HughesTooling
@lange_18  What format are you trying to export to? Also what is in your design, can you share an example f3d file you can't export from?
Mark
Mark Hughes
