Announcements
Export Form Tool Models
I have several form tools that I'd like to export as models, is this possible?
jeff_strater
can you explain a bit more about what you'd like to do?  What format do you want to export these models?  And, for what usage?  You can convert Form/Sculpt bodies to BRep bodies, and then all neutral formats will be able to be used for export.  Or, are you looking to export these into another Sub-division surface modeling product?
Jeff Strater
Engineering Director
seth.madore
Or there's a third option that the OP is looking to do, and that's the "Form Tool" function in the Manufacture workspace. If it is this third option, no, it is not possible to export these in any manner.
Seth Madore
I have many form tools in my tool libraries over the years that I no longer have the sketches for, I was hoping there would be a way to export them in, lets say, a step file to send to my colleagues who are using Gibbs and Solid Works.
kandennti
Hi @Anonymous .
In the past, I created an add-in to import/export form bodies. (The extension is .tsm).
https://github.com/kantoku-code/Fusion360-TSplineBodyDoorway
The format of the tsm file is supposed to be here.
https://github.com/GrapeTec/T-SPLINE
