Fusion Support
export f3d file
2 REPLIES 2
sapto_romadi
101 Views, 2 Replies
export f3d file
after making 3d model ball valve and the component create full in fusion 360, but when i will export not available f3d extension file, but f3z fil extension...how to show f3d ?
2 REPLIES 2
jhackney1972
in reply to: sapto_romadi
If your model contains an External reference file or contains a Configuration is will be a F3Z file when exported.  You can Break Link most of the time for an external file but if you have a configuration in the model it will have to remain an F3Z file unless you want to export only one configuration member.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
sapto_romadi
Thank you so much your answer get me out from my trouble.
