Announcements
Experiencing program freezing / Crashing when in Manufacturing CAM
Hi all,
I hope you can help recently we have been experiencing freezing / Crashing of Fusion 360 when opening files that contain CAM when switching from Model to Manufacturing the program freezes then then crashes there are no error messages or recovery files.
I am able to open file quickly I can quickly right-click the CAM setup folder and delete all of the CAM.
I would like to troubleshoot the CAM program but I am unable to do this before the program crashes so I am wondering if anyone has experienced this issue and can offer some help?
In total we have 3 licenses 2 being used in production and one in the office I am thinking this maybe an issue with one of the production PC’s tool library maybe?  I am also replacing one of the PC’s in production in January because its running Windows 7 the other two PC are running Windows 10 its should be noted this file crashes all 3 PC’s when you try and open it and examine the CAM.
I have attached an export Fusion 360 file if you wish to try it.  Please be aware this will likely crash your Fusion 360.
seth.madore
I can reproduce this as well. I think the issue is your In-Process Stock, which is turned on by default. You can turn it off here:
Seth Madore
Thank you very much, this has helped me debug the CAM program without fusion crashing Thx.
seth.madore
Fwiw, it has been fixed in an internal build, so it will make it's way to the customers in the future
Seth Madore
