Fusion Support
ExactFlat - SelectionCommandInput is not visible
2 REPLIES 2
anna_lisovskaya
197 Views, 2 Replies
Hi! When I use ExactFlat and select pieces as described in tutorial I receive an error 'SelectionCommandInput is not visible' and then 'NoneType' object has no attribute 'clearSelection'. I don't understand what's wrong. Screenshot 2023-04-06 at 22.39.20.pngScreenshot 2023-04-06 at 22.39.13.pngScreenshot 2023-04-06 at 22.35.33.pngScreenshot 2023-04-06 at 22.35.49.png
2 REPLIES 2
I have the same problem. Did you solve it?
@ignaciosoloriot Reading this post, the user contacted ExactFlat and it seems the Fusion plug in is no longer supported. You'll need to extract the face\faces in Fusion's Surface workspace using Offset face with a zero offset (this creates a copy).
Then in the Mesh workspace convert the extracted face to a mesh (Tessellate command).
Then right click the mesh in the browser and select Save As Mesh and export as a OBJ file.
Then upload to the ExactFlat website.
EDIT. Looking at their website I can't see anywhere to upload so not sure if they only support Rhino and Solidworks now.
Mark
Mark Hughes
Owner, Hughes Tooling
