Announcements
event simulation solving
2554428C
2554428C
I am testing out event simulation in fusion 360. Very simple, using only 2 components which are primitives: one cylinder going at 900m/s against a 50mm steel plate, just for fun. i did the checklist, which said everything was fine: i assigned materials, i fixed some parts of the steel plate and the cylinder, and added the initial velocity. i launched the sim but it doesn't end, it seems stuck at the solving stage. Is there anything I can do to solve this?
Marcin_Kosciolek
Autodesk Support
Autodesk Support
Hi @2554428C
The Event Simulation is a very time-consuming type of analysis. The question is, what size of a mesh and what total time did you define.
Marcin Kościółek
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
2554428C
I use 15mm mesh size and the total duration is 0.001s. it is still running...
Marcin_Kosciolek
Autodesk Support
Autodesk Support
Hi @2554428C
Are you able to share the model?
Marcin Kościółek
2554428C
https://a360.co/2Wii1AL
here is the public link
Marcin_Kosciolek
Autodesk Support
Autodesk Support
Hi @2554428C
I calculated your model. It took about 1:30h. After that, I modified the study a little, I set the bullet as rigid, and I added extra deletion criteria (principal strain). Now, the model is calculated after 1 minute.
Here is the link to the upgraded model by me:
https://a360.co/2Yd7uHZ
Marcin Kościółek
2554428C
wow thank you very much, so it's just a question of time; i thought my simulation was stuck after a while...
