hello, Ihave this alert ! can I do ?
Solved by innovatenate. Go to Solution.
@jeff_strater This looks like an odd thing.
@Anonymous could you try to uninstall and re-install Fusion 360 and see if that eliminates this error message ?
@ekinsb, is this add-in something that you recognize? Do you have any clues about what might be going wrong here?
@innovatenate, have you seen anything like this before?
I mounted parallel desktop with windows 10 to try Artcam Free, but then I removed it
When you uninstalled, did you use the Fusion Cleaner?
Looks like it may be related to the MakeTime add-in @Anonymous could you have a look?
You may want to go through the process of uninstalling the Add-In to see if it helps. I hope it does!
