Error When Running Generative Design
egobrien
egobrien
Hi, I'm not quite sure why this is failing. I had a previous version of the file working and since then I have added additional load cases and changed constraints, but I don't see a reason for this to fail. Any advice?
henderh
Hi @egobrien,
Could you attach the f3d file so we can take a closer look? (File > Export...)
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
egobrien
I was able to resolve the error. It seems that my design was not constrained enough causing the generative design to fail.
henderh
That's great news you were able to resolve the issue. We appreciate the follow-up!
Hugh Henderson
