Announcements
Error: The selected faces could not be offset After Sculpt Modeling
Rockks
Rockks
Hi guys, I have a problem when I'm trying to do an Offset Command. I saw a similar post saying about the reason of this problem are the numbers of triangle and distortion of mesh; I tried to fix it but the problem still happens.
jeff_strater
can you share the model, and some more detail about which faces you are trying to offset (preferably a screencast)?  Hard to tell without more information.  Areas of high curvature will cause offset to fail.
Jeff Strater
Engineering Director
Rockks
Hi jeff, I appreciate your help. After many tries, I got a solution that was to move some faces in Sculpt mode before doing a split modification to avoid some problems like the last pictures are showing (Split modification created little pierces). And now it's ok.
Thank you for your attention.
