Announcements
Error starting Fusion after uninstalling insider edition
shawn3WMTV
shawn3WMTV
I uninstalled the insider edition and re-installed to standard version.
Now every time I restart Fusion I get the error as in attached screenshot
Any suggestions on how to fix this?
jhackney1972
Did you use the Clean uninstall before installing?
John Hackney, Retired
shawn3WMTV
yes, I used to uninstaller, rebotted, and then installed the retail version.
HelenChen-ElectronicsQA
Hi @shawn3WMTV,
Thank you very much for reporting this issue and so sorry for any inconvenience.
The reason why you met this is because the database version used in Insider program build is newer than the one in Production build.
Could you please try below steps?
1. Close Fusion firstly
2. Delete the Electron folder from:
Windows OS: C:\Users\{Username}\AppData\Local\Autodesk\Autodesk Fusion 360\Electron
Mac OS: $HOME/Library/Application Support/Autodesk/Autodesk Fusion 360/Electron
3. Relaunch Fusion
Then this issue should be gone away.
Thank you very much for your patient to trying with Insider program.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
