Error Reports Storage Location
When my Fusion 360 starts up, it comes up with the submit error report and when I submit the error report, it closes. However, if I move the error report screen to another monitor or maximize the fusion window, I am able to continue to learn the software normally.
I have performed a clean install.
This started when I tried to delete a bunch of items from an imported STL file that had been converted out of mesh to Brep. The delete failed and the software crashed and wanted to submit an error report. I normally do not send error reports as a matter of course and canceled out of it. Ever since, it wants to send an error report and even if I do send one, it does not resolve the problem. I can assume that it has stored the error report outside of its normal operating area (one not cleaned by the Autodesk clean install program) and keeps on detecting this error report and starting the online submission process that always seems to end with the software being closed.
As a developer myself, I know that if the software had ACTUALLY crashed when I started it up, I would not be able to sideline the error report and work on files using Fusion the way I am doing right now as a workaround the problem.
Since I have the person edition and only qualify for support via the forums, I am asking if anyone in the community has seen this behavior before and knows what I can do to delete the error report (or other data) that is causing this to occur.
Also, I would be interested to know how to turn off the error reporting completely. In this day and age of privacy concerns and ever-increasing government regulation on companies regarding privacy, this should be an option.
