I can't open a file. I read a post with the same error but there's none update... how can I solve it? 😞
Hi @JHRendon
Can you share the file using one of the methods in this article and post it here on the forums?
Then also try and re-upload it to Fusion and open it?
Yes, this is the link https://a360.co/2Ebic3T
Hi @JHRendon
I'm seeing the same error. I'm thinking what probably happened was Fusion closed while saving the file which corrupted it. You might try reverting to a previous version of the file or looking through your local cache.
You can create a copy of an .f3d file you find there and open that file in Fusion.
Let me know how that goes.
It does not work... 😞 The same error happens. 😧
Hi @JHRendon
Can you try both of these files and let me know if either of them work:
It works!!! 😄 Thanks a lot, Karina Harper. Let's be friends. 🙂
Haha my pleasure!
And yes definitely. We're friends now.
Hi, Karina.
I seeing the same error. can You help me?
Thank You
