Announcements
Error: new ef_int outside edge
I'm trying to cut extrude a lip on the edge of an enclosure and I keep getting this Error: new ef_int outside edge.
Not really sure what it means or what's causing it. Thanks.
dsouzasujay
Hi @Anonymous ,
Would you able to attach the file here or you can send the file directly to  (sujay<dot>dsouza<at>autodesk<dot>com)?
That'll help us to investigate the issue.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Thanks for replying back, I was able to avoid this error by duplicating the sketch and it worked somehow.
