I have been using my laptop for occasional use of Fusion 360 but recently I have got the above error message in the data panel. There is an option to work off line but when I take that it says "insufficient data"
I have found a similar issue reported on the forum and have tried all of the following with no success:-
- When the data panel is not displaying does refreshing its display have any affect? e.g. F5 on Windows or Command + R on the Mac The messages disappears but the egg timer keeps going
- Clearing cache files: In Fusion go to "?" menu then Clear user cache data. This will clear existing local cache files and then restart Fusion. Does this help? No difference
- Are there any proxy servers being used? VPN? NO
- If a firewall or antivirus is being used try turning it off and relaunching Fusion to see if it has any affect. Both switched off but no change
- And just to confirm there's no problems with the projects/files can you try connecting to your hub via a web browser and check the accessibility of the files? Go to www.autodesk.com and sign in to A360. Are the projects/files listed? YES Can you access file info for the files e.g. comments, renderings, versions, etc.? YES and All works well on my desktop computer
- Have you recently installed any hardware or other applications regardless of whether or not they use the internet? NO
- Can you send us the diagnostic log files? You can generate these within Fusion by clicking "?" > Diagnostic Log Files. YES attached
- Finally, has this always been a problem or started just recently? Just started
