Fusion Support
Error message on Fusion 360 Personal Use.
1 REPLY 1
usama_ahmed2SXBK
84 Views, 1 Reply
Hi Team, Kindly assist with below as  soon as possible.
Issue: Error on fusion 360 access: The design contains neither solid bodies nor sketches. A drawing cannot be created" in Fusion 360.
Action taken: found active fusion 360 personal active subscription under account.
Article: provided steps from  the link for the error: https://knowledge.autodesk.com/article/Warning-The-design-contains-neither-solid-bodies-nor-sketches...
But User still facing error after following steps, kindly assist.
1 REPLY 1
This error has nothing to do with subscription status or license.  It is actually fairly self-explanatory.  You must have at least one solid body (drawings now support surface bodies, as well) or sketch in the design before you can make a drawing of it.  Other body types, such as mesh cannot be placed on a drawing.
Jeff Strater
Engineering Director
