Announcements
Error in 2D Contout path
louisvanderveer
louisvanderveer
See below error from Fusion360 after trying to create toolpath 2D countour:
Enabled feature flags: live-machine-connection setup-sheet-viewer tool-library-v4-release
Invalidated: Generation failed
Error: Internal CAM kernel error. Please report through your support channel.
seth.madore
Can you share your Fusion file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply/
Seth Madore
louisvanderveer
Herby asked file.
HughesTooling
Problem is for the number of step-downs under mutiple depths you have 0.2. Probably should show an error or not allow anything but a whole number in this box.
Mark Hughes
Owner, Hughes Tooling
