Fusion Support
Error: Failed coilfunction for knurling.
11 REPLIES 11
Message 1 of 12
jorbakken
214 Views, 11 Replies
Hi.
Happy new year everybody.
I`m trying to make a knurly pattern on a knob using the coil-function, but I get an error-message either by making the first half revolution or by mirroring it.
I get two different errormessages. Either:
or when I finally get a line and try to mirror it;
 I`ve tried to change patterns upwards and downwards. Making a new "target body" to see if I`ve done something wrong with the first object. Searching and speculating for answers. I`ve seen several videoes on youtube and it looks like this should be a easy thing to manage.
Does anyone know if I`m doing something completely wrong or if it`s a issue with the Coil-function?
11 REPLIES 11
Message 2 of 12
g-andresen
in reply to: jorbakken
try circular pattern
günther
Message 3 of 12
jorbakken
in reply to: g-andresen
Hi Günther.
My plan was to do like in the video: coil- mirror - circular pattern. The problem (like I showed in the screenshots), is the error messages I get both when I use the coil-function for cutting and the mirror-function for copying, wich means; I don`t have at base-pattern to transfer to a circular pattern. The problems occures before I get to the circular-patterns-function.
Message 4 of 12
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
Message 5 of 12
jorbakken
File attached.
Message 6 of 12
g-andresen
Watch the screencast and play with the coil data, especially the coil height.
Pay attention to warnings!
günther
Message 7 of 12
jorbakken
Thanks for taking the time making the video.
I tried doing it exactly like you did, but I still get the error-message:
As you can see the sketch is a bit shifted compared to the body, but like you, I just move the body in position when editing. I tried altering revolutions from 0,25 to 1 and section size 1 to 2, but it`s still the same error-message:
Message 8 of 12
jorbakken
..and I also experimented with the hight.
Message 9 of 12
g-andresen
1. follow the timeline in shared file
2. start a new design
3. service utility > Repair
günther
Message 10 of 12
jorbakken
Hi.
I tried the repair-function. That was a good suggestion, but it`s still the same:
Maybe I should try to delete Fusion and reinstall it? I don`t know. I`ve been going at this for weeks now... I just can`t wrap my mind around what the problem might be.
Message 11 of 12
g-andresen
1.Does my file contain the result shown in the screencast?
2. please share the latest version
günther
Message 12 of 12
jorbakken
Hi.
1. Yes
2.  Latest version below.
