Fusion Support
Error 22
6 REPLIES 6
tea03013
301 Views, 6 Replies
Error 22
I can’t help but uninstall or install Fusion 360. Error 22 appears
6 REPLIES 6
jhackney1972
in reply to: tea03013
Take a look at this webpage.
John Hackney, Retired
@tea03013 The logs shows the below error:
ERROR :: The registry is locked at this moment. Please refer to detailed information: "This process failed because of another installer deploy in process"
Likely restart the machine and try again and this should go through.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
tea03013
in reply to: jhackney1972
didn't help, the error remains
@tea03013 On your desktop do you have the Fusion shortcut that you use to launch Fusion? If you do can you please delete that and try again?
Autodesk Fusion
Join Fusion Insider
It didn’t help, everything just gives an error. I do not know what to do. I tried all the methods that are on the forum, but it didn’t help. This didn't happen before
@tea03013 Everything points to the same Errno 22?
Can you confirm what you have done so far please?
Autodesk Fusion
Join Fusion Insider
